This command is used to add an LDAP domain. The new domain can be added as the default. Older default domains, if any, will no longer be the default since once only one domain can be default at a time.
domain_name |
Name of new LDAP domain to be added |
N/A.
Use this command to add an LDAP domain.
You can see the LDAP domains added by using the show ldap domain command.
Supporting multiple domains gives ExtremeXOS the capabilty to send LDAP queries to gather information about users belonging to different domains but connected to the same switch.
You can add upto 8 LDAP domains.
The following command creates an LDAP domain with the name "sales.XYZCorp.com and marks it as the default domain:
create ldap domain sales.XYZCorp.com default
This command was first available in ExtremeXOS 15.2.
